That’s why I always had one vertical and the other horizontal. Figured it would give me a broader range for antenna polarization. Ever take apart one of those, “diversity” antennas? I wonder what’s inside. Is it just a loaded coil or something? If I can find them in stock I’ll buy an extra just to cut it open.With diversity antennas, if they are close to each other, its best the tips are in a different Plane to each other. This is why the tips should be at a 90 degree angle to each other. Even having them both straight up closely with one higher tip than the other can work also. Still being in a different plane to each other. If they sit close together at identical Tip heights, this negates the diversity effect advantage
