Mr.Vylan
If you're in control, you're not going fast enough
- Bay Area, California
- Felony
- Kraton 6s
- Senton 6s
- Senton 3s
When I throttle the hub assembly turns (slow) as if under pressure.
QUESTIONS:
PART 1
I know, I know too many questions and variables. I simply want to avoid replacing parts since I'm not sure if it is the slipper clutch assembly or the motor.
Again, when the slipper clutch/gear is not attached the motor appears to be spinning fine.
Thanks in advance.
- My motor is spinning fast by itself but sounds a little rough.
- The slipper clutch appears to be functioning <-- newbie, so only assuming
QUESTIONS:
PART 1
- Is a motor either working or not?
IF NO, - If the motor has bad bearings or something internally wrong will it not be able to turn the driveshaft at normal speed?
- If the slipper clutch is bad, how can I test it?
- If the slipper clutch is binding (bad), will it prevent the motor from optimally turning?
Thanks in advance.
