AaronF
I noticed this when I went to get a photo for my build thread. The front wheels aren't pointing straight... is that normal?
The photo's with the body on are when I used bench as a guide to straighten them in relation to the bench, ie true direction, notice the front left is pointing way to the left.
The no body photo is when i plugged a battery in and is centred off the servo, now it's the right hand side pointing to the right. Rear wheel point inwards for some reason as well.
I changed the servo saver some ages ago and the servo. I also replaced a lower control arm as well on the LH side. Other than that I haven't touched it, the links are fixed length so I can adjust them.
Could it be from setting the servo end points to prevent it binding? Seems strange and looks wrong.
