- Kraton 6s
- Typhon 6s
- Thread starter
- #41
The esc is cutting power at about 78mph using the 34 pinion so going to try a smaller pinion to see if i can get a bit more speed before the esc cuts power.
Basically the motor and the gearing creates the load to the ESC (amperage)That’s a larger pinion by all accounts. More teeth and larger size. Why would you say smaller? I’m confused. ??
My bad. I just went back and read the older posts where you said that the ESC was failing with the 34T pinion. Now I understand. I was assuming you were coming from stock pinion.The esc is cutting power at about 78mph using the 34 pinion so going to try a smaller pinion to see if i can get a bit more speed before the esc cuts power.
If you guys do not already have the Bolo speed calculator I highly recommend it. (you can download an excel spread sheet to keep on your computer)
https://www.scribd.com/document/358412341/Bolospeed-Rc-Calculator@LibertyMKiii .. Do you have a link for where I can get it..?? please ???
I don't think a gimmick, looks like cause more drag.Yeh it was over geared. Got the 25t pinion in the car just now and the new aero kit. ( probably just a gimmick but looks good )
Hopefully get a run in either tomorrow or monday.
How many cartwheels was that crash ?Got the 29t pinion on and still cutting out under piwer but seems to be even worse than the 34t pinion. God knows whats happening there. The 27t pinion is going on tonight and hopefully get the goal out of it.
On a side note, never run when it starts to rain a bit. doesn't end well haha wasnt even that wet, looked damp but obv to little grip. ( the picture was taken after it had a sudden downpour after the crash )
Damn bro!!
Yeh not great idea to run in the wet lol.
What gear spool gear T are you using again?
Are you coming on throttle smoothly as u build up speed?
If your just flooring it from low speed will cause esc to cut out.
Ive just installed my limitless spool last with 34 t gear .
Ima run 30/34
If you ever want to upgrade esc the 120a mm2 is a monster 6s esc!!
I think maybe so.
Thst gearing is really high too.
I got limitless spool now.
Gonna try 27/34 .
Thats higher rstio then 34/50.
Hopefully 110mph gearing.
Did you get your typhon sorted??
