How you liking those new springs?
So far so good man. I did some other tweaks to the shocks to get everything to my liking but they are solid. Just enough movement that I’m not getting the bouncing I was with the tie rod setupHow you liking those new springs?
Think i fried a cell in each pack,won't take a charge, or discharge..1 was 1st run on 8200mah HIGH CYCLE LIFE smc 150cGreat work!! 100mph barrier is a huge achievement
Did you figure out anything with the setup that could have caused that issue??
It got me stumped a little.
I’d kind of start from square one and look everything over on the car.
I would also run the exact same setup again to see if it happens again, then maybe change one thing at a time.
If it happens again, run different batteries, then go from there.
Have you checked where the wires attach to the cells in the pack?
Are those another product line that do not have a warranty like the SRD line?Think i fried a cell in each pack,won't take a charge, or discharge..1 was 1st run on 8200mah HIGH CYCLE LIFE smc 150c
So it was a new pack, had it been cycled or this was just charged and sent?Think i fried a cell in each pack,won't take a charge, or discharge..1 was 1st run on 8200mah HIGH CYCLE LIFE smc 150c
Charged an sent.So it was a new pack, had it been cycled or this was just charged and sent?
Not sure I'll have to check
I've never had a problem before mismatching packs but I think from now on I'll make sure they're matching packs they're both 1p batteriesCharged an sent.
Not sure of the brand but yes it's a 0.8 mod on the HR slipper eliminator.You still using .8 mod, I was about to order the eliminator but thought I had to swap to mod 1.. I have a ton of .8 pinions, what spur did you go with, is it the HR one!?
Yup just put the raised collars of the slipper eliminator right into that countersink and they line up great.
Good job manNew PB with infraction. Only 2 mph off from my best speed with my typhon. Only running 3s right now until I get a 4s from smc.
Longest ru i ever made too.
Thanks bro. Figure out what's up with your v1 yet?Good job man
Nah. They have been sitting on the end of the bed I've been relaxing for once and talking to @LicketySplit instead of getting stuff doneThanks bro. Figure out what's up with your v1 yet?
Is this your infraction?
No the infraction is still the infraction. This is a different build that I had going…Is this your infraction?
