- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
I figure now that we have a speedrun section of the site it would be good to post a thread about motor KV selection. Motor selection is a mystery to many and although I don't have it all figured out (I am not the experienced expert) I believe I have a pretty good understanding.
First I want to say that Castle ESCs like the XLX and MMX8s are really the only 2 good options. This is because you will need high amps and data logs to make informed decisions on adjusting your setup.
Running a Typhon as a buggy you would likely be limited to a 6s setup or running a Limitless you could run up to 8s. First things first you must know what power level you plan to run and how large of battery you plan to run. As of today the top 3 batteries for speed running would be the Turnigy Graphene/Panther, CNHL 70c, and SMC True Spec Extreme V2. You will need the best of the best LiPo due to their amperage delivery and reduced voltage sag. On the topic of voltage sag higher mAh values will help. This is why you will see many guys run 2 packs in parallel. A parallel 6,000 mAh setup would effectively give you 12Ah!
Next to begin the discussion on KV of motors you must know that most if not all motors are hand wound. This means no 2 motors are the same. Some are power hogs and some are highly efficient. I recently purchased the SkyRC motor analyzer and if you are serious about speed running this would be a wise purchase. The 2 big things this tool will give you is actual KV and how efficient in amperage draw your motor is.
This first example is a good TP4070 with the D-wind 2080KV
This is a good motor that my friend has done 159 mph with on a 1/8 Mugen. You can see here the amperage draw is “efficient” at 3.6A
The next was another TP4070 with the D-wind 2080kv it would be an ok motor, but it will draw more amps (around 2x the other motor) and run hot! Also notice the KV difference of these 2 motors both sold as 2080KV. While higher KV would pull slightly more amps we wouldn't expect it to be this much higher. Ideally TP Power should have taken this motor back as "bad".
(note I had tried charging my 2s testing LiPo fully to 8.4V and same results came out.)
Back on topic to selecting a motor. The Magic is shooting for your motor to run around 51-55k rpm knowing it wont quite get there. Reviewing logs of people who have truly gone fast, their motor RPMS are in the high 45-49k rpm range to as much as 52krpms.
KV multiplied by the voltage = the motor RPM
The topic of voltage sag here and data logs is key! Without testing your motor, gearing, and battery... the best thing we can do is use typical numbers.
Typical value of a 6s Lipo drops during a speed run to around 19 volts. On 8s it drops somewhere to around 26 volts. These numbers are for 5000 to 6000 mAh packs as described above as "best LiPos" I have seen far worse sag on low end LiPos.
First we can look at a 6s setup. If I want 51k RPM I will take 51,000 divided by 19 volts and come up with 2684 KV. This is why many people like the 2700KV motor for 6s use!
The major key with this setup is that you cannot over gear it. The higher KV motor like this will pull some serious amperage. I would recommend starting conservative and use you data logs as you make adjustments. You would be keeping an eye on RPMs, voltage sag, amperage, and ESC temps. With a Typhon/Limitless differential running GRP tires you could expect as much as 154 mph with 27 pinion and 34t spur gear. (assuming your car gets there safely and has the aerodynamics to do it) Given that you should not go out your first time and do 150mph I highly recommend gearing way down on this setup and work up to that gearing.
There is a mobile app called "RC Car GearCalc" that I use. this one does not have you pick 6s 8s 5s etc. Instead it allows you to input a specific voltage so that you can use it to properly adjust for voltage sag.
Next we will look at 8s!
For this again our around 34 volts will sag to 26 volts. (this could differ depending on the batteries you choose.)
Again shooting for 51,000 rpms divided by 26 volts provides a motor of 1961 KV. This would be why speed runners recommend 2000 KV up to 2200 for 8s use. (This is why I purchased the 2080kv TP 4070 motor)
Also why I am using my BLX 2050KV on 8s! Which that motor is actually closer to 1900kv
Most scenarios we find that staying under 1:1 gearing is ideal for 40mm motors due to the gearing torque loss. Also keep in mind that the gearing creates the amperage load for the ESC and if you over gear you will not reach the desired RPM range. Always start low and work your way up. Read the data logs and adjust accordingly. At a certain point the car will not go faster but the motor heat and ESC heat will go way up. At that point you have reached the limits of the setup. You have 2 options. Try a different motor or in my mind the better option is to improve the aerodynamics.
People are now playing with large 1/5 motors which are around 1000 - 1350 kv. I am not certain yet how all of this will play out as their power band will be different and requires some gearing way beyond 1:1
It is also worth noting that TP Power 1/5 motors are 6 poles and the more poles of the motor will provide more timing stress on the motor as it has less time between each pole to do its "job".
I hope this is helpful and again I am not a proven expert on motor selection, but I believe this is at least a good ballpark for you!
