Uncle_buck
So I took my notorious for its maiden voyage today ran it first on 4s then on 6s when I drove it on 6s after a while I had no steering when the truck was on the ground but when I lifted it I had full steering
For a little bit but it will work its self loose again with the blue.I'm definitely gonna do that tonight will the blue be enough that's all I have on hand @TraverseCity420
If it works, you have to let us know asap. The loctite fix is working for now, but a more permanent solution would be huge.Fast eddy makes a quick adjust and jam nut for the losi 5th scale line I wonder if it would fit in the arrma 8th scale that would keep the saver from backing off ?
If you let the red cure long enough, it's almost as strong as a weld. If you do come up with a magic bullet, let us know asap.I know the red works but from what I hear it comes lose as well over time I've loctited ot already with the red I just want to find something more permanent so you don't always have to mess with it if not it is what it is I guess
I put red on mine couple months or so ago. I won't run it until it warms up/dries up outside, which will likely be the end of April. 4+ months should be plenty cured by then.If you let the red cure long enough, it's almost as strong as a weld. If you do come up with a magic bullet, let us know asap.
