Thank you bog!!
The video won't play for me either.
Most of the play in mine seems to be coming from the bushings between the steering posts and the steering post fins. If I look up under there as I turn the wheel by hand through its play range I can see the fins rocking up and down. Ideally they would have no movement in that direction.
Some shims there should work but I have not had a chance to experiment with it. Of course the other option would be bearings instead of bushings.
What are the rest of those bearings for?Hi
I would say get enough to do the whole truck, here is a list of what you will need.
2 Rubber Sealed Bearing 10x15x4
10 Rubber Sealed Bearing 5x10x4
2 Rubber Sealed Bearing 5x13x4
2 Revolution 4x7x2.5 these two are for the steering
