Timmyn71
I have a futaba 4pm and in order to get my rig to go straight my steering trim is set to the right at 64 and still wants to head left at a semi high speed. A'm i missing a tire adjustment some where?
YepDid you ensure the servo was centered when you put the horn on and that you've set your endpoints? Just always good to check.
TYes, most likely the servo was not centered when you put the horn on, or you attached the horn to the servo at an angle.
thats why I am asking this question was centered with the horn that’s why I am puzzled
Thanks that's what I was thinking of my toe but visually I can't see itIs your toe set pretty straight if anything a hair inward /\ also may have a bad bearing on that side or your droop is set higher on the opposite side pushing rig the other way. Just a few more things to check
Ya if anything maybe a hair inward but don't toe out \/ as one side will try to follow the other when toed out.Thanks that's what I was thinking of my toe but visually I can't see it
