- Redondo Beach
- 4x4-Mega
- Felony
- Granite
- Infraction
- Limitless
- Kraton EXB
- Mojave
- Senton 3s
- Typhon 6s
- Typhon 3s
This is a drag build I quickly built using some spare parts.
Includes:
- Used Limitless Roller
- Stock Diffs (3.308 or 43/13)
- 46t Infraction Diff (1 mill diff fluid... I think?)
- Spektrum 2050kv motor w/ 25t pinion
- MMX8S ESC
- CHNL 90C 6000mAh gplus 4S LiPo
- Radiolink RC6GS v2 w/ R7FG receiver
- Yokomo Drify Gyro V4
- ProteK 130T servo @ 7.5v BEC
- BSR foam wheels (Pink)
Unfortunately, after a couple of using some prep (corn syrup based sticky goop) for traction I ran into some diff issues. I forgot to shim them up. Rookie mistake. Especially when using prep on foam wheels your diffs need to be solid, because you'll be putting a ton of load through it.
Here is the car:
Here is the GPS:
Here is the datalog:
Includes:
- MMX8S ESC
Here is the car:
Here is the GPS:
