dms70
So my V3 Kraton isn’t stock anymore. M2c chassis, Voltage aluminum throughout, HR hubs etc. Electronics are max6 Hobbystar 4082 2000kv 16t. Diffs have all been gone through (more than once) 60/100/30. Running Proline Badlands (not mx38)
Ok so what seems to be out of the blue, while running yesterday, I believe I was experiencing thermal cut off. Running in dirt with some grass also. Grass I know can have a lot of resistance, but this had been cut recently and I stayed out of it the best I could. Originally I thought I had hit lvc but the elapsed time didn’t make sense. After refreshing my memory on the led status of the max6 I knew what to look for. But the thing is I never saw any blinking green or red. It would sit for a few maybe 5-10 minutes, and run again. A buddy said he did see the thermal led blinking so I believe him, but when I would check it, I saw nothing. The day was cool at around 65deg and cloudy. This isn’t a new set up as I’ve run it before, even at same location. I had recently picked up some new 6s single packs and thought, jeez I’m not getting good run time out of these. But I think I had hit thermal before, but just didn’t think to check. I guess I didn’t think of it because the default setting on the max6 is 221deg f and never thought it was getting that hot. I would normally always touch it, but perhaps internally it was hotter? It has a working fan, and I run the Yeah Racing heatsink with dual 30’s on the motor. Anyone experience similar or have any suggestions? I know I can drop pinion size, but I was under the impression that would affect motor temps more.
