You’ve inspired me lol..My tires are always in the shelf dirty or dull looking. Even after cleaning good with a brush and simple green. What product can i use to make them shine without the drawback of damaging them in the longrun?
Inspired to vaccum seal?
So purdy they are.
Apparently its the same product they use on their wipes but in liquid formI imagine to some extent they are vulcanized some how in the molding process. Probably are not 100% rubber. But even scale tires are not 100% pure rubber. Scale tires will dry rot just like RC tires will.
All those Boutique RC and even Bicycle products are way too expensive. Just Snake Oil at $16. a bottle. That is just a complete waste of coin IMHO. To each their own.
Probably works, but no better than just using Dawn dish soap. It says both Tire and HAND Cleaner???? What a Joke. Come on now. Even sounds like some magical Snake oil do it all $16. stuff.
When it comes to RC Boutique products, much is just repurposed basic chemicals. That gets marked up and branded for "RC use". Cow markets their stuff hard. LHS's and all love to push this stuff like it is some staple needed RC item. I bet the high profit margin supports it well.
The short answer is: yes.
I do have that an old bottleThis is what I use on a lot of my rc plastics, also works well on tires. I use it to get rid of the white residue after tire glue dries, does a great job and leaves it non-greasy and clean.
I honestly had no idea. I know as much about rubber as an oral surgeon knows about rectal surgery.The short answer is: yes.
The follow up: Technically speaking, all rubber is vulcanized as the pellets from which it's made would be useless to the consumer so, I'm not quite sure what you're asking.
If you have ever seen my rigs, I look the clean/shiny tire look.My tires are always in the shelf dirty or dull looking. Even after cleaning good with a brush and simple green. What product can i use to make them shine without the drawback of damaging them in the longrun?
My w40 silcione spray i put a tiny bit on my 4s pivot balls are still wet since yesterdayNope. Silicone spray does not attract dirt. It is the bee's knees for RC...
Lmao so whats the freaking point of using it. Maybe thats why i hear squeaking after one runOne downfall to silicone spray is that dust and dirt participles can be attracted to the spray, causing a higher chance of squeaking after the Lubrication was performed.
https://trhservices.ca/technical-insights/silicone-spray-vs-wd40/
I have dry PTFE lube. But i never noticed it do anything to be honestIt was never meant to be used on rc cars in the first place.
Use Wax based bike chain lube for lubing stuff on rc cars it doesn't attract dirt, it's actually supposed to help repel dirt. Yes they are making this stuff with Teflon again https://www.walmart.com/ip/DuPont-M...23_qNx40TT7Nx7YXCXSIhVvobFRFBg-MaAufgEALw_wcB
Hah, you left the following sentence out which is essential.
One downfall to silicone spray is that dust and dirt participles can be attracted to the spray, causing a higher chance of squeaking after the Lubrication was performed. For this reason, if you are lubricating a tight area, it is essential to clean the area first with a degreaser such as WD40 then only use a small amount of silicone spray to help lubricate the area.
So yeah, silicone spray FTW
