It’s a TP 3650.That motor is small for a Talion, the 1/8 Arrma's use a 40 series motor.
It would fit in your BigRock but it's too short to be that effective torque wise, it would still be a better motor than the stock Arrma..!!
Good motor. I'm 99% sure this is the exact same motor and this is the normal price:I use this in my Talion with Mojave chassis
https://www.rcjuice.com/motor-esc/b...ensorless-motor-1-8-truggy-monster-truck.html
Currently on sale for $70. Normal $90. I have the 1730kv variant.
Yes I know it's not a 36mm x 50mm, I just don't believe it's good enough for a 1/8 as almost all would use a 40mm can.It’s a TP 3650.
Not a 36mm x 50mm motor.
It’s rated for 4500 watts. I believe the stock Talion motor is in the 3000-3500 range.
That makes sense. Thanks. I have no experience with TP so I was simply going off the wattage rating.Yes I know it's not a 36mm x 50mm, I just don't believe it's good enough for a 1/8 as almost all would use a 40mm can.
I own quite a few TpPower motors in various sizes, that motor you quote is powerful but not really suited to 1/8.
According to TP, that motor is more powerful than their 40x73mm motor. Doesn’t that mean it’s more powerful than a stock Talion motor?It would turn your BigRock into a crazed wheelie machine, use the Max8 should be fine, or any of the 3s Arrma lineup
(Granite maybe too short for it to fit)
