Granite Turning issues
josedellc
I seem to be having turning issues with my Granite, when i turn left or right it starts to buffer and the wheels will literally shake!! Any help?šŸ˜…
Sounds like a faulty servo. Fairly common. Contact HH they will likely send you a replacement.
thank you man, i started doing some research and with the help of you guys it was the servošŸ™šŸ½doing gods work
Check if the endpoints of your servo travel are set correctly. razorrc has a video how to set them via the transmitter. If your endpoints are set too far, you'll ruin your servo in no time.
