Typhon Typhon 3S insufficient front and rear differential oil
bicketybam
RC Grand Champion
New Milford, CT
BigRock 4x4, Granite, Infraction, Kraton 8S, Kraton 6s, Kraton 4s, Mojave, Notorious, Talion, Typhon 6s
Nope can turn them with little finger (almost no resistance), LOL. Might need to rip them open and check. And good videos that have a teardown on how to get to the diffs? Im familier with the Outcast 6s, but this 3s plastic chassis is new to me.
Remove the center drivesshaft
Remove the red stopper that hold the motor module in place.
Remove the motor module
The rear diff come out with the 3 long flathead screws underneath the diff.
The front diff comes out with the same corresponding 3 and a 4th long screw behind the underneath of the diff. There are videos posted in a sticky.
pandianightcross
Texas
Outcast 6s, Typhon 3s
Looks like it for sure , One thing I like about Arrma, easy to work on "mostly" . Now if you ask me to do me erevo 1.0 diffs, I be like ......"I really don't wanna, I really really don't" HAHA
razorrc
If you're going to break it down all the way to the diffs, you might as well change out the bearings too.
Gray Fox
Finland
Typhon 3s
I changed the bearings as well while changing the diff fluids. Original bearings rattled a bit. Used Avid rubber shielded bearings. Big improvement over the stock.
Uz3r
South Australia
BigRock 4x4
I opened my new-ish BRCC diff a while back and it was also only filled about 1/4 with oil... maybe 1/3 tops.
A question I have: if you remove a 3S diff and are holding it by the output shafts in your fingers and then turn each shaft in the opposite direction - how firm should it feel? Mine is quite firm, I have to quite firmly grip each shaft with my fingers to turn slowly. I've always wondered if this is normal or if its supposed to turn easily and freely.
bicketybam
RC Grand Champion
New Milford, CT
That's normal.
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
Mine were very hard to turn by the output shafts. What I do is temporarily attach the driveshaft and use that to get a better grip on it. It should be smooth, but have resistance. Make sure to go a few turns in each direction. Take your time. If you feel any kinks or notches, stop and recheck the gears.
Gray Fox
Finland
Typhon 3s
They are very firm and that is the way it should be. There are rubber O-rings around the output shafts to prevent diff fluid from leaking out. Those O-rings makes it pretty tight for turning even when diff cases are empty. Filled with diff fluid, the turning becomes even tighter.
GRC
Granite
Yesterday I decided to check the diff oil for my Typhon 3S. When I remove the diff, I was able to easily turn the drive couplings, its as like there were no oil and there were no leak. When I open up the diff, both the diff cups were only a 1/4 fill. I wonder if any of you guys have this experience?
I opened the diffs in my Granite 3s when it brand new and they were only 1/4 full.
Create account
Log in
piccopower For Sale Trade my Kraton 6s for Typhon 6s Classifieds 1
J Typhon Typhon Mega Overheating Arrma 4x4 0
Mr.Vylan Senton Typhon 6s / Infraction 6s / Limitless -- can't decide Arrma 4x4 23
A Granite Typhon 6s shocks Arrma 4x4 4
Similar threads
