I wonder if he’s talking drag time/speed rather than top speed with a longer runway.on 6s that setup should go 100+
Smc 5500 6swhat lipo are you using?
Ok I wana do drag. I just ran my car n did like 67mph in 132 ft. Took like 2.5 secondsI wonder if he’s talking drag time/speed rather than top speed with a longer runway.
@snupe - can you share more details about what you’re trying to accomplish?
I wana get my car down the strip quick asapSmc 5500 6s
I’m trying to get this thing to rocket out the hole. So I should get the 42t spur n change to a 21t or 22t ?That's too much gear for 6s and 2700kv... back down the pinion to a 21 or 22 and see what happens, rc calculators don't always translate to real world results in a drag scenario... Also, some prep on the rear tires will do wonders, I'm sure you're spinning on the line at least a little
I’m trying to get this thing to rocket out the hole. So I should keep the 42t spur n change to a 21t or 22t ?
With the 25t I got up to 67 mph in the 132 but it wasn’t that fastI’m trying to get this thing to rocket out the hole. So I should get the 42t spur n change to a 21t or 22t ?
Thanks a lot for the info. Really appreciate this I’ll get back to you wen I get the new gear setup n everything timed I’ll let you know the time n speedLeave the spur for now and jump down at least a couple teeth on the pinion. You can make tire prep really easy at home for cheap, it's just messy but if you wanna go fast, you gotta use it.
