- Notorious
- Talion
- Typhon 6s
I've seen people mention that 2.8MT tires are about the biggest that should be put on the stock 6s Typhon because it doesn't have the spiral diff gears like the Kraton/Outcast/etc. Are the spiral gears compatible with the stock Typhon diff cases? Or is it cheaper/easier to just buy some diffs from JRC? I am planning to go up on tire size once I burn through the stack of buggy tires I have. May go with 2.8MT size, but would like the option to throw a Kraton 4s body with some Backflip LP's for increased ground clearance.
