Awesome thank you, That was it. Plus very quick reply!!You have to take out your front upper a-arm hinge pins. The hinge pin holder is attached to that plate from the bottom of the plate so you cant free it up till the plate is removed..
I run that piece in aluminum as I was breaking them often. You can get the exb one or there are aftermarket ones.
