Let me present you my Typhon dragster (maybe 8th Scale /OutLaw Extreme) :
All start with a classic V1(?) typhon
I first change the chassis for a kraton one
And I use red spacer to connect the body with rear shocks tower. I also use fazon srpings.
And I did a homemade wheelie bar
I install a XLX esc mounted on alza racing part
And a big motor mount
Foam tires (thats last 5 runs max)
A rear ftx wing was modified and upsidedown use for the front wing
I also instal a big motor : kill potor rc 2900kv race spec motor with a cap-pack :
The V1 version looks like this :
But I decide to change some parts; tires becaus they don't last a long time ... front and rear shocks/shocks tower and small other parts.
So i first install alza racing 1/5 wheel adapter with big grp tires
I change front and rear shocks/shocks tower with infraction one's
I also change spacer and body mount for talion mount. With rear infraction tower, holes arenot in the same place so I need talion mount (witch are not in line) to use original body hole (or close)
And I install a belted center spool diff
And now it looks like
Thanks for reading
Thanks for reading
