Typhon Range Issues
J.nelson0385
Hey everyone I have a Typhon Mega 4x4 and switched it over to brushless with the 85amp and 4000kv Spektrum set and it is crazy fast but after the first run I started to notice after about 50 ft away from me it cuts off no more signal until I get about 50 ft away... .Never over heated and tried few things but nothing worked so I am asking for help, Please help me get back to bashing!!!!
I would look at your receiver antenna - best case is that the antenna slipped out of the antenna tube and you can put it back in to get your range back. Worst case is if you pinched the antenna wire while swapping electronics and damaged the coaxial cable so you longer have a functioning antenna - in which case a replacement receiver is probably necessary unless you have the knowledge to swap cables and tune the antenna.
I did that last night and took it out for a quick test and it did get better range it doubled atleast but not like it should be i feel I mean before the upgrade to brushless i was going to the other end of the block without hesitation so I guess i have to look into new esc or something
https://www.amazon.com/dp/B07MCNW79...abc_MF0J2MR4TVDM26ZJH50G?_encoding=UTF8&psc=1
I bought this for my typhon dx5c transmitter
This transmitter has good range a
Few videos on youtube about its range
Its eazy pezy to install, then im using a 3s mini lipo as power, splice wire together boom range is a mill 😂 dx5c has ok range but stupid range now cant even see car Im putting a panic alarm on it in case I lose the car
I messed up and bought the 4inch make sure to buy 6 or 8inch one 😂 that's why mine look like that owell..
