Figured I would share this video. It's from the United State Office of Education, basically military secret stuff.
Hysterically large soldering iron and components aside the same principles still hold true. You didn't go to the gym in those days, just pick up the soldering iron.Super interesting! I suck at soldering tho. Smaller jobs are easier. However, the more I do it, the better I get!
Yep. I'm actually closer to Richmond tho. Which has an awesome dirtpark if you've never been. Kinda ghetto tho. LolHysterically large soldering iron and components aside the same principles still hold true. You didn't go to the gym in those days, just pick up the soldering iron.
Keep practicing it will get easier.
BTW I'm assuming that East Bay is Oakland<->Fremont. I'm a bit south of you.
I've heard of the dirt lot in Richmond but never been.Yep. I'm actually closer to Richmond tho. Which has an awesome dirtpark if you've never been. Kinda ghetto tho. Lol
You were my neighbor.Still pretty much the same. I was on 28th and Barrett. In pinole now. Much better place. Lol
Yes. I believe waffle house closed down too. Didn't make it thru covid.You were my neighbor.
Yes, Pinole is much better. Do you remember Zips? It was the late night hang out I think it's a waffle house or something now.
Tin is twice as conductive as lead and has a higher melting point. Both of those mixes are easy to work with. I'd use 60/40 tin\leadWhich is a better mix for RC connectors? I have 2 rolls of 1.6mm diam resin cored solder. Thought they were the same untill I realised one is 40% tin/60% lead and the other is the opposite at 60% tin/40% lead. Does more lead reduce the melting point? I've only used the Sn40/Pb60 and had no issues so far.
So more tin, less lead = higher melting point. That's what I thought. Ok thanks.Tin is twice as conductive as lead and has a higher melting point. Both of those mixes are easy to work with. I'd use 60/40 tin\lead
This helps me also. Thanks.Tin is twice as conductive as lead and has a higher melting point. Both of those mixes are easy to work with. I'd use 60/40 tin\lead
Glad I could help. It's rare that I canThis helps me also. Thanks.
3 biggest issues I see people have:
-Soldering irons without enough wattage for the situation.
-Holding the heat too long
-Not pre-tinning / not using flux
