Others have asked or mentioned in other threads about not knowing how to influence tires with acetone.
it’s super easy and the most effective way. Simply put your tires in a sealed container big enough to hold the wheels and something that can keep them off the bottom of the container.
Fill to just below the level where the acetone touches the wheel. The fumes let it sit overnight and the fumes will break down the glue. You can pull them right off without a heat gun or anything.
( I can post pictures later of what I’ve used In the past if anyone would like a visual reference . )
