- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Could you advise what I might be doing wrong? I recently tested a TP Power 4050 motor with a delta wind rated at 3840kv.
On a SkyRC motor analyzer it tested at 3817kv. This falls in line with what I expected as many motors test slightly lower than the rated KV.
When I did a test on the MMX8s connected to 2s LiPo the logs are indicating a much higher KV value. For reference the motor is free spinning in the air. (graph smoothing is disabled) I tried the 1:1 gearing option and No Gearing/Direct drive option and both netted the same results. I also tried with 10 degrees timing and 0 degrees timing, but also came out with the same results.
34,256 rpm / 7.9V = 4,336 KV
Maybe @robert@castle can shed some light on this subject.
