Rainger40
- Granite
- Kraton EXB
- Senton 3s
I think the V3 input gear may be different. I redid my slipper and used the new nut that goes in the slipper shaft and it kept the drive unit from seating on the input Gear shaft. Wouldn’t slide back all the way, not enough to clear the ledge and “click”. I’m pretty sure the nut was all the way down in the slipper shaft and it wasn’t happening. Took it off re-adjusted, loctite, ect and then it went on as usual easy peasy. Anyone else run into this?
