Senton Vehicle shuts off
1967chevelle
Wondering if someone can help me just received my senton I don't get enough run time before it shuts off already replace the ESC with new one from Factory and still have a problem with not enough run time before vehicle shuts off
What battery are you using?
It runs for about 1 minute and a half to 2 minutes then shuts down so esc cools down then it works again
20 c
So why does it shut off
why does the smaller C rating make it do that
ESC is calling for more power than your battery can deliver and it's overheating it. If you keep using it you will fry the ESC. Just get a better battery that meets or preferably exceeds the minimums.
Wow thanks so much you have been a great help I'm a crawler guy just thought I'd try this out
Which Senton is this? The Brushed Mega? The BLX3s? The 6s?
If this is the MEGA, then really the only thing you can do is run the stock Nimh, and let it cool between runs. Running it even on a 2s lipo will thermal the ESC in about 10 minutes, I would think the 3s would thermal it even quicker.
Getting a higher C rating won't help with the Mega. If you have a BLX3s or 6s Senton, then yeah, a 20c lipos won't cut it.
Yeah, but this quote makes me think Mega. I have not heard of the BLX truck overheating, but almost everyone that runs the Mega 4x4 on lipo has heat issues. And the OP is running 3s, I didn't try that. I had enough fail on 2s with the stock motor.
