- Kraton 4s
- Outcast 4s
- Outcast EXB
- Talion EXB
Still waiting on the arrma ones to ship...
So, found these new Vitavon cases. I bought two of them to try out for center diffs. Almost same as arrma. Aluminum (they also have silver available) with a removable steel end. The steel end does not use the arrma gasket, but the gear side does. Steel end has an o-ring seal. Went together easy, no play in the output shaft. Actually only fit the 2 shims behind the pin. Seems great quality with the fit and finish.
Will switch out with the center I have on the Kraton this weekend and report back.
