You can bend the shock shaft back. I don't know of any shocks that will work though. Sorry. Must have been a big jump for THAT to break?
Yeah the Powerstrokes for the Slash should work as well. I stayed up super late last night updating the shock thread then searching for shocks, I must have spent like 30 minutes trying to find springs to run on the Felony/Infraction/Limitless shocks. I might dig into it a bit tonight or in the morning.
I believe TLR 22 SCT 3.0 shocks are 90mm front, 110mm rear.
I heard that a lot about them when searching for shocks for my 4Pede, everyone said go with GTRs. They are really nice but not cheap.Replace with stock shock/shaft/rod and tower for now as one option.
I think that this was major user error. I don't think trying to bend that shaft back will be any good.
I had bad luck with a set of PL shocks, that leaked out the box. Cust Support was a zero, even after sending them back to look at. Parts were hard to source from PL also. Just my experience.
I want a set of the TRX4 shocks for my SCX10-II.The TRX shocks are actually very good. I have TRX GTS shocks in my all my Axial crawlers now after trying many others. They make a good bottom cartridge in most of their shocks. Rarely leak if you know how to build shocks well enough.
They do make some good shocks. Got them from JennysRC for a song.
What Hot Racing top part?I got the hot racing top part for the rebuild since the chasis is about the same for the granite and the Voteks, maybe the shafts are out there to, i hope that helps.
Those are for the Granite, Senton, Typhon and Big Rock Crew Cab. They might work in the rear of the Vorteks.Hot Racing ATF155AR08 Aluminum Threaded Rear Bleeder Shock Bodies Arrma 1/10 4x4
https://smile.amazon.com/gp/product/B07QZXJR2P/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Well, you might be able to make them fit but they are definitely gonna be too long. If you had got the HR front shock bodies for the Granite it probably would've been a better fit on the rear of the Vorteks.ahhh well they for the rear so insure do hope they work. I havnt been able to find a proper replacement yet and man i wanna run this NOW!!!! lol
hmm maybe ill do just that.Well, you might be able to make them fit but they are definitely gonna be too long. If you had got the HR front shock bodies for the Granite it probably would've been a better fit on the rear of the Vorteks.
