old was 3200kv, new is 2800kv. exact same 18t pinion, haven't ran properly yet, will be running on 4s when the batteries arrive.
Just so you know, I am also giving the thing the smallest possible throttle.
4s with more power would solve?
I had set it to CCW, turned it on and drove wrong way. swapped switch on transmitter which swapper the movement of the trigger, it was very fast in reverse but slow in forward. Changed to CW and now much faster going forwards. Assuming because I set reverse power to 25%?
