Was about 77 ambient. Have a decent fan ready to go on it. Don't know why but I thought stock pinion was 15 but looks like it's 12, so that explains why it was getting hotter than I expected.what was outdoor ambient temps? If it’s 85+ and you were drawing heavy constant amperage the rig is geared appropriately. Get a high cfm fan setup on the can if you want to play hard during hot days. Or give it a break every 5 minutes…. I’m 18/46 max 6 combo and have a 40mm rocket and it’ll go hard all day under 80 degrees ambient.
Fan is the next step - yes its well heavy with the 1650 and batteries. Cheers for the replyFireteam is heavy, I think 20t with fans is what I would do but maybe you should add fans and see what it does for your temps with the 18t
Nice one - cheers. I have a fan setup ready to go but thought I'd run without for 1st run.I run double 40mmx 20mm fans and no Heatsink , just a double fan mount, All else is stocker 6s electrics. ( 2050kv) My FT is Heavy, without much of any upgrades
I'm running a 17T/50T, my motor temps get over 160F if over 85F outside. Cooldown are simply necessary when in hot weather. 1
15T pinion was the OE Speed gear, FWIW.
I imagine a 1650kb motor with a 21T pinion is equivalent to my 17T in this regard.
Need a nice fan setup TBH.
You can't really evaluate the best Pinion size, if your Fan solution is not in place already. You will be chasing a ghost, if that makes any sense.
you have to remember with the new motor the kv is lower so you HAVE to gear it higher than stock if you want the same speed as stock.Was about 77 ambient. Have a decent fan ready to go on it. Don't know why but I thought stock pinion was 15 but looks like it's 12, so that explains why it was getting hotter than I expected.
