A speed square works for me. also if you turn or drift let's say right more than left you end up with uneven tire wear. As far as I know, the only way to change rear toe on an Infraction or limitless is by changing the rear hinge pin block. I tried a 0-degree block and didn't like it for street bashing but works well on my drag HobaoLooking at the tires, it’s not too far off but can depend on what you mainly do with it. If you want it set up perfectly and even after using a Set Up Station, you’ll still need to tweak it to your likings. Those can cost from $90 to a copla hun.
I’m gonna try one more pack. So that will b 4. Just got these gonna beat these next
Vipaz are the best drift tires around. just don't try speedrunning on them.I’m gonna try one more pack. So that will b 4. Just got these gonna beat these next
I thought camber also but didn’t wanna touch anything until I got help from u guys. Thanks. And all I’ve been doing is drifting and donuts. Lol
