SergTalionV3
- Talion
I think I found the right one on ebay!Yes, you can add a connector in series. They do it in the factory. It's not magic.
You can also buy an adaptor so you don't even have to solder.
Any advice where to get adaptor? Really trying to get in this. Thanks a lot for help!
A hakko or Milwaukee m12 iron are good.What can I use to solder? I know I need stuff but
Which one?
But it would be better to solder another connector directly to the ESC wires.
^ This is a parallel connector which doubles the capacity (mAh).I think I found the right one on ebay!
Any in the retail? Advice pls^ This is a parallel connector which doubles the capacity (mAh).
You need a series connector to double the voltage:
2x 3s 5000mAh parallel = 1x 3s 10000mAh
2x 3s 5000mAh series = 1x 6s 5000mAh
You need to calibrate the esc. Power on the transmitter. Power up the car while you hold down the set button it will blink red and beep. While tx (transmitter) is in neutral push set button, should flash green. Know hold full throttle, push set button ,green light. Know hold full reverse hit set button should be two green flashes. Then power off. Power back on you should be good.Yes, got it! Thanks!
Now I have the other problem...next...I created new thread...doesn’t want to run, but steering is working, esc blinks red
Whoops, good catch
Awesome it did work! Thanks! That was an easy fix and a good piece of info for future!You need to calibrate the esc. Power on the transmitter. Power up the car while you hold down the set button it will blink red and beep. While tx (transmitter) is in neutral push set button, should flash green. Know hold full throttle, push set button ,green light. Know hold full reverse hit set button should be two green flashes. Then power off. Power back on you should be good.
