I run a 20T on 6S. If you’re running 8S, you’ll want to drop to 16T. More than 20T is beyond fast on 6S and not really usable IMO. Tires will blow off the rims.hey guys
How much max pinion i can put on "motor mount v4" ? 22,24th...?
And which pinion i shuld run with 1650kv motor..on 6s. Arrma kraton v3
Thsnks
I personally run 24/46 on my hobbystar 1480 and 1730kv motors. I think 22 is about as big as you can go with the 50t spur. I should note I run fans on my motors. And before another post goes up the xmaxx 8s heat sink will fit the 4985hey guys
Thsnks
