Doubt it the v2 came out recently.Thinking to buy 1, but is there any news if there is comming a new 1? Or an EXB?
I doubt Arrma is going to make a Kraton 8s exb, they beefed everything "the most they could."Especially now that they come with the EXB versions ... I wouldn't be surprised that such is coming.
I’ve been wrong before though. I said Arrma would never make a road car....
on the original engine, what is the max pinion size?If you get the latest version you should be fine. I have the 1st and bought it the day they were available. I did not like the radio which I changed out or the flexy chassis which I also changed. Center dif oil was too thin and the stock pinion way too small. Those areas have been addressed by Arrma with a good radio (I have the dx3 in another model), better bracing, thicker stock dif oil and you can always buy a bigger pinion. Down the road you may need a few things if you want to turn it into a something more extreme. I still love mine...
Mine came with the 23T pinion in the box, so I’d try that before buying anything different.and you can always buy a bigger pinion.
that great! mine came with a 17t I think and nothing else. 23T should be pretty exciting.Mine came with the 23T pinion in the box, so I’d try that before buying anything different.
I made my own motor slide for the bigger 56mm motors. There are several now available. @PPS-RC is an arrma forum member and makes top notch stuff. This is the gorgeous slide he makes for the big cans.on the original engine, what is the max pinion size?
and is an other engine plate needed when you place a hw 1100 or 800kv?
Nice!!that great! mine came with a 17t I think and nothing else. 23T should be pretty exciting.
https://practicalproto.com/collections/frontpage/products/30mm-motor-insert-for-arrma-kraton-8s
Maybe PM him or use FB messager and see if he ships outside the US.Nice!!
Thanks for the info.
(unfortunately im not located in usa)
Nice!!
He does, I ordered directly from his website (Switzerland). Can really recommend his products.Maybe PM him or use FB messager and see if he ships outside the US.
I threw a 25T on my stock electronics and have had no issues with heat. She absolutely shreds on throttle-- very fun!that great! mine came with a 17t I think and nothing else. 23T should be pretty exciting.
What is the range of the Dx3?If you get the latest version you should be fine. I have the 1st and bought it the day they were available. I did not like the radio which I changed out or the flexy chassis which I also changed. Center dif oil was too thin and the stock pinion way too small. Those areas have been addressed by Arrma with a good radio (I have the dx3 in another model), better bracing, thicker stock dif oil and you can always buy a bigger pinion. Down the road you may need a few things if you want to turn it into a something more extreme. I still love mine...
