Greengaunja
Ise da by' dat burns da Senton........
ArrmaForum Fan
- Durham Region, Ontario Canuckistan
- Senton 6s
- Senton 3s
- Thread starter
- #61
No worries. I'm still learning so critical feedback actually benefits me. Thanks.
The reverse throttle part I've done with the Radiolink several times with no issues before. But it only takes that ONE time to hardwire it into my head that it's a no-no. Thanks for telling me that and rest assured it will be the last time I do that on ground powered up. That explains one thing at least.
1. No, in fact I triple checked both ESC and radio fail safes for proper setup. After you mentioned it, I just checked again. All good.
2. The main visible things were set at zero prior to calibration. I actually reset the profile just before(thanks Alan!)
3. This is the second time brownout has been mentioned. Still learning and would appreciate more info on it or a link as searching it gives many mentions with little detail. As for servo, it's a 35kg JX Ecoboost HV. You are right about that though. Seems fine when on stand and poops the bed on ground.
LuckySSR JX Servo Ecoboost CLS6336HV 180° 35KG Large Torque Servo CNC Coreless Digital Servo for RC Crawler Car Helicopter Robot Boat https://www.amazon.ca/dp/B0872CRKJD/ref=cm_sw_r_apan_glt_i_AJH3VT3B23VQ12G1Z348?_encoding=UTF8&psc=1
What you said gels with what jkflow said after the fire. Actually brings me peace of mind because I like the RadioLink, I'm used to it now. Knowing both incidents can be blamed on me helps. I can see how I got lax and careless and based on what you both said, I failed to followed proper procedures.
Why is this good? Because that's something I can fix and change that won't cost anything but rather instill safer habits.
