- Kraton 6s
- Notorious
and this is why I am done with the hobby......
Say it aint so, Fat Cat !!??!!??and this is why I am done with the hobby......
Both my rigs are up for sale. I haven't had time to post pictures on the ad but ya they are for sale. They didn't catch fire but I'm tired of fixing something every run and I barely use them. I did have a battery explode but not in the car just in the storage bag.Say it aint so, Fat Cat !!??!!??
Say it aint so...........
Thats why i loved amazon liposStarting to think the best way to get a refund is to not ask for one. Wrote Zee and asked about hardcase high burst 4s lipos and sent pic explaining why. Even stated it was likely a failsafe failure. Just got this email response:View attachment 167013View attachment 167012
I think they misunderstood. I was asking for a better hardcased option recommendation.
Granted, hard packs ARE better and safer. But that smack could have had the same result. In fact I'm surprised about something I've been concerned about.That is one reason that I do not use soft packs.
#HardPacks4Life
I was wondering the same thing with my RC6GS. I don't like radios with long initialization pauses where it acts like it has to go on a literal walk through memory lane just to find the rx - while the servo is doing its own thing. I just had a PM1373 go poof during a start up. I knew it had something to do with the damn radio. I'm going back to the dumbo. I just wanted to try it out but I lost a Primal for it, never gave me a problem with the dumbo either.FYI, on your initial problem. Just tried something with my Radiolink RC6GS V2.
I was playing with throttle expo etc with a servo installed into the throttle channel, but long story short:
If the transmitter is off, and you just turn on the receiver, the throttle (servo) advances ~ 30% travel for the first ~2s until the receiver initializes.
This gets increasingly worse if you power cycle quickly on/off i.e. the servo was at max after 3 power cycles. This is with fail-safe at 0. One time is enough though to send the rig flying.
Servo/throttle etc will go back to normal after you turn on transmitter and stay in fail-safe when you turn it off.
Very poopy radio design tbh.
Yes, receiver was properly bound etc. Try it out yourself, with just a servo connected. I have never seen this on any other radio type. So much for cheap electronics.
You ARE right on that part. My RC was looked over and tested for a warranty claim at the LHS. Their tech guy wasn't familiar with Radìolink and spent two days fiddling around with it because they are swamped with repair orders atm. Even installed my receiver in another car to familiarize himself with its functions. Horizon was good about this. Just wanted to be sure the failure was with Max 6 and not the transmitter, I was told that the way they spoke with the LHS, this has happened before. There will be no warranty claim, however they are putting new battery connections in for free. They feel the Max 6 will function properly and was undamaged(other thanFYI, on your initial problem. Just tried something with my Radiolink RC6GS V2.
No, mine were soft case. Yet I will recommend ZEE just for their customer service. I wrote and asked if they had hardcased versions as I saw none on Amazon. They DO make them but had no stock. And refunded my Amazon account (didn't even ask). So I ordered a pair of HRBs 6000MaH 50-100Cs. Yeah, soft case again but I'm going to mod up my Hot Racing battery mount with some carbon fiber plates. Basically make front and side walls mounted to the tiny ones already there.Weren’t those Zee 5200’s hard case lipos? They look just like mine, and mine are hardcased. I just got 2 3S gensacearespammers basher batteries and they’re soft case. Makes me a little nervous, especially after a tumble that managed to eject them once. I’ve been cinching the crap out of the Velcro straps since then.
Hell even that comment helps.Of course I am no help here for the problems. But wanted to send some good vibes bro. Hope u get it figured out.
I notice this with some radios. Radio ON 1st. Radio Off last. I don't rely on FS at all. Especially when initializing any ESC.FYI, on your initial problem. Just tried something with my Radiolink RC6GS V2.
Charge 'em up and shoot 'em. Use a junk charger and charge it outside."THE GREAT RE RE REBUILD!" Lmao
So true. So true. I wasnt sure what I was dealing with when I grabbed it and stuck my fingers between body and fenders to shut it off. And when I took the body off, left it for over an hour didn't even attempt to remove battery(the rc isn't worth whatever could happen if second blew up). The officer approached it until I told him there was a possibility of the second lipo going off. By this point I already had my fire extinguisher from my truck ready.
That's just it. I expected an explosion but got the slow hot burn instead. And im very surprised the second didn't go up. It even looks usable, although I'm chucking it. Can't ever trust it.View attachment 166949
^^^This.@Greengaunja Not sure what the heck you've got going on. Sounds like you did everything in the right order this time. You've been using the radio link for a while so it's not that you are just unfamiliar with it. At this point I don't even want to venture a guess, I'll let the guys with brains chime in.
OK, just remembered to ask, have you created a new profile, and set up the radio from scratch, instead of using the setup you already have? some times it helps to clear it and create a new one. just a thought.
Alan gave me advice on calibration issues I had before. Just before the fire incident, I reset everything to zero and calibrated. I did keep my other profile for the 3s though and even though I switched receivers, I used a different profile for new 6s setup@Greengaunja Not sure what the heck you've got going on. Sounds like you did everything in the right order this time. You've been using the radio link for a while so it's not that you are just unfamiliar with it. At this point I don't even want to venture a guess, I'll let the guys with brains chime in.
