UncleDizzle
So I was out driving my outcast doing a speed pass and then hit the breaks pretty hard which is nothing uncommon for myself (or for most drivers I assume). But immediately after I had no throttle momentarily. So I started creeping forward and it cut out again. And that’s all it will do now is creep forward and then cut out. I’m running 30/47 with a castle 1100kv. It also fair to note I did just switch out my duffs for new ones and also added metal diffhoisings on them. And installed new cvds in all four. Shouldn’t make a difference I don’t think. But it was only my second run with the new parts. And most importantly I’m getting this error signal from castle. If you listen closely you can hear the beep barely audible with sound of the fans. I’ve emailed castle but I’ll get a quicker explanation from you guys. And thank you in advance for any insight. You guys haven’t let me down yet.
Also fair to note upon start up everything is normal. I get the 8 beeps for 8s and all that. The error beep doesn’t come on until I give it throttle. I also forgot to mention I’m running two SMC 4s 1100mah batteries.
