For good 2,3s speed with these cars ya really need 4000+ kv motors cause ya can't gear much higher than 32/30 with mod1 gears...this motor will get me to the 101+ mph 2s goal I'm after soon as I max stock setup outThat ought to make it move.
My 30t pinion doesn't fit with my 34t spur!!900ft hits in subdivision,kept cutting..will need to take it to spot.remove huge wing an try again
Yea mod1.. yep, catching on the lil lip in the bottom right corner!!Mod1??I've ttc of 64 ,but shaved module down..
Dermal it an it'll fit.thin gears help too.Yea mod1.. yep, catching on the lil lip in the bottom right corner!!
Yea I was about to b-line it to HobbyTown to see if they have a 32t trashass spur.. doubt it, I'll call.. might have to order one and get passed up!!Dermal it an it'll fit.thin gears help too.
63 is biggest ttc that'll fit...33/34=63ttc would fit..you'll need a smaller spur gear..
Sh*t!!Removed wing an rear got loose twice at 75ish.ill either add some rear wing.....no ill raise rear of body,keep it stock...so hard for me not to modify
I got 82mph completely bone stock had to use 2 3s in parallel to get it that made the diff between the 76mph mark I just couldn’t crack for a while ..good luck with it……big thank you to a brother that Pinter out a word I used wrong in my response that made me sound like a dumbassNevertheless,that's great speed for that stock system.pushing stock setup will be fun,gonna use 100% outa the box stuff.should be interesting to see what swapping mmx6s for stock esc will do,what stock 3900kv will do
You mean in parallel?I got 82mph completely bone stock had to use 2 3s in series to get it that made the diff between the 76mph mark I just couldn’t crack for a while ..good luck with it
Duh yesssir I guess I think I’m dislexia sometimes that I got the correctionYou mean in parallel?
