.2mmWhat’s your z-distance setting between the support and the object?
Printer: Creality CR-10SIs this PLA spool new or has it been hanging around awhile..?
Have you tried to dry it before use?
Also, give us some info of your settings that you're currently using so we can better help you.
Plus, what slicer and its version are you using?
What printer do you have? Stock nozzle size or modded??
.2mm
Slicer: Cura
Nozzle: stock
Also, the filament is only a couple months old and has been dried recently (Polymaker filament). Do you want my Cura support settings?
.2mm
Slicer: Cura
Nozzle: stock
Cura moment. Do you have the current version? 5.3 i believe. I try to avoid tree support for this very reason. They improved it on 5.3 still not amazingSo, lately my supported structures are looking quite bad. Not sure what the problem is, but I did notice my supports and supported structures aren't touching, not sure if that's the issue. See attached pics
Layer height is also .2 and support angle is set to 60 degrees, I will set the z support distance to .12Support is .2
what's the layer height?
What's the support angle set to?
Funny story about cura.. it won't produce z support distance numbers lower than layer height.. and .2 is not going to give a good first layer look.. run the layer height at .12 and a .12 z support distance.. it will look better.. also make sure you have enough meat (1mm) on the support roof to be able to pull it cleanly.. a concentric roof against a line first layer separates best..
yes, I have Cura 5.3. Also, the problem still exists with normal supports.Cura moment. Do you have the current version? 5.3 i believe. I try to avoid tree support for this very reason. They improved it on 5.3 still not amazing
The second pic is pretty normal. Could improve it for sure but genrrally parts of the model who need support like 90 degrees will look bad once the support is removed. Won't harm the function of the part. It will just not look esthetically appealing
Here are my Cura support settings, I haven't messed with them much.View attachment 305784View attachment 305785
Is that a custom rim design?
If not then attach the .stl file here (or PM it to me) and I'll run it on my printer & settings to see how it turns out on my end.
Will do, I'll change my Support Interface Pattern to Zig Zag, and I think I will try 50% on the density first and see how it goes. I have something on the printer now and I only have one printer, so it may take a bit before I can report my finding. Thanks for the help!Your Support Interface Density looks to be quite low..
I'd suggest you bump that up to 50% (maybe even go Bold and crank it up to 60-65%.)
Plus, set its Support Interface Pattern to Zig Zag ,to achieve a much "cleaner" surface finish.
Just my humble 50cent opinion.
Is that a carbon reinforced filament?If it were me printing that part I'd be running .06 layer heights and .12 z gap.. yep, it takes longer, but I'd rather have a cleaner looking part.. layer lines drive me crazy..
.06 layer height exampled below..
Thanks for your advice, I'll give it a try(Those parts look AWSOME!)Yeah interface pattern set on grid is no good.. any pattern is better than grid.. I prefer concentric.. but as long as the print pattern and support pattern are different it will release..
I run 100% roof density in all support situations, last thing I want is chunks of the support staying attached to the model.. I'd rather have a nice pop sound and remove it all in one chunk.. ..
But I don't think you will ever get a clean first supported layer with a .2 z gap.. it's always going to look crappy imo.. I would only use .2 on huge areas of supported material, just so it's easier to remove.. but will undoubtedly look like crap..
If there is ever anything I need absolutely perfect, I toss it on my crx and print the supports in PVA with 0 z distance... of course this is not an option for printer's that don't print multi material..
Just regular PLA, thanks though!Is that a carbon reinforced filament?
If so, what type is it? The carbon reinforced filaments ive used all specify minimum .2mm layer height
