3D Print Support Issue
Ok, so I printed a support test using the adjustments Camaroboy383 and Tex Koder suggested and the quality is definitely better, but is there
anything that I can do to make it look even better?
Might be a stupid suggestion, but have you tried the latest creality slicer instead of Cura?
Eventhough it also runs on the cura engine, i've experienced simular quality degrading ever since cura 5.1~ish on my ender 3v2
i switched back to creality slicer a couple of months ago with 'slightly' better results
Still looks like a .2 layer height no?
The layer height is .2, but the Support Z Distance is .12.
I'll check it out, I just figured it was exactly the same as Cura.
Ok let me reiterate... Cura will not allow a lower support z height than the layer height..
Meaning you printing at .2 it defaults to a .2 z support gap.. if the number is lower than layer height it rounds up... To get a .12 z support gap the layer height needs to be the same or lower..
I'm going to have to write that down so I'll remember that point! 👍
Thank you. 🙏
I'm coming to have to write that down so I'll remember that point! 👍
Thank you. 🙏
For some reason it's been like that forever, and never fixed.. but even if it was it would need to be a multiple of layer height... So a .12 would never work as it's not even in the ballpark of even steps..
Wow, that makes a lot of sense. I'll print a new test! 👍👍
Just printed a new support test at .12 layer height, looks pretty good, I imagine that's as good as it'll get.View attachment 306162View attachment 306163
It is definitely heading in the right direction and is much cleaner.. 👍.. so next try upping your support roof density to 100.. it should make that upper square pad cleaner on the first layer..
I believe the half ball/ cone is about as good as it's going to get aside from going to a .06 layer height
The support roof density in the picture was 100%.
Oh, support roof and support interface are enabled correct?.. roof being the most important..
