yea, i thought the HRB would work, but its actually longer than it described. i see most 3s are 138mm, should work just double check, don't want get one ,then it doesn't fit againI'm sure the details should be on the sellers page?
The HRB 5000 for sure won’t fit in the SWB. It fits in the LWB with both blocks out. The SWB only has one block to remove.I fit a HRB 6000mah 3S in a granite chassis... just have to take out the blocks.
I’m assuming the 6000 is bigger and it fits in the granite chassis just fine... and yeah I guess there is only 1 block I thought there were 2 lol but it still fits....The HRB 5000 for sure won’t fit in the SWB. It fits in the LWB with both blocks out. The SWB only has one block to remove.
which block are you refer too?I fit a HRB 6000mah 3S in a granite chassis... just have to take out the blocks.
The block that is held in by 1 screw on the bottom and makes your battery tray bigger when removedwhich block are you refer too?
i heard really swelled battery need to be discharge and disposed due to fire hazard.Ironically enough my battery just swelled after a run in my granite the other day. I’m wondering if the battery is too powerful for my truck and is overheating it.
thanks, didn't know what that block was, i guess its battery spacer.The block that is held in by 1 screw on the bottom and makes your battery tray bigger when removed
Nope it’s the opposite. Your lipo was overrated and swole up due to its inability to keep up with the ESC demand, OR you drew it down too low below LVC.Ironically enough my battery just swelled after a run in my granite the other day. I’m wondering if the battery is too powerful for my truck and is overheating it.
does esc have volt threshold for auto shut off, when lipo voltage too low?
