4S Typhonied Granite(TYGR) Build
aneft
Fort Collins
  2. Mojave EXB
  3. Outcast 6s
Hey all. I’ve almost finished collecting all the parts for this custom ground up build which are listed below. My one concern for a weak point running 4s is the plastic 3s driveshafts and the differential gears and outdrives that I’ve mentioned problems with in another thread. Would I be able to use the Outcast 4s A arms, Driveshafts, and hubs on the 4x4 chassis for more strength? Are there hop up planetary/outdrive gears out there or anyway to use 6s diffs? As always, this group is awesome and I look forward to your input??
  • 4x4 SWB Chassis
  • Integy Steering Bell Crank
  • Typhon 3s RPM Suspension Arms
  • Typhon 3s Turnbuckle Tie-Rods
  • Arrma CVD Slider Driveshafts
  • Typhon 6s Shocks
  • Tekno Shock Springs
    • Front-80mm Yellow
    • Rear-90mm Orange
  • M2C 3075 Arrma 16mm ZRS Shock Caps and O-Ring Shock Pistons
  • Hot Racing Aluminum Pivot Ball Set
  • 4s Slipper Clutch/Spur Gear Assembly
  • Hot Racing Steel Helical Diff Rings/Pinions
  • Hot Racing Aluminum Differential Carrier Case
  • Hot Racing Aluminum Differential Yolks
  • Adjustable Motor Mount
  • T-Bone Racing Front Bumper
  • Arrma Wheelie Bar
  • DSM Off-Road Bearings
  • Hot Racing 17mm Hex Adapters w/ 10mm offset
  • Pro-Line Badlands MX28 2.8” w/ F-11 Nitro Wheels
  • Pro-Line Ford Raptor Body
  • RC Maniacs Unbreakable Granite Body
  • Castle Creations Mamba Monster X
  • Castle Creations 1515 Sensored Motor(2200kv)
  • EyeSky 20kg Waterproof Servo
  • FlySky BS6 Receiver
Yes you can use the 4S arms, driveshafts, hubs, steering blocks, bearings, turnbuckles, axles, hexes, pins, and nuts.
I assumed the 4s driveshafts were metal but after looking they are just wider and still composite. I’ve seen metal hop up driveshafts for the Granite and Typhon but I’m worried they’ll just bend and they aren’t cheap.
Update pics on the build. Need to paint the Ford Raptor body I received today then just waiting on the front bumper and 4s Lipos. Nearly there!
Damn nice build. These things are money pits... amirite ?????
  • 4x4 SWB Chassis
  • Typhon 6s Shocks
  • Arrma Wheelie Bar
  • Castle Creations Mamba X SCT
  • Castle Creations 1415 Sensored Motor(2400kv, 5mm Shaft)
  • Aluminum Motor Heatsink w/Twin Cooling Fans
Build complete except the body is waiting for paint to arrive! Gonna be sad but glorious to get this beast dirtied up!!
