dubesinhower
- Vorteks
I've had my Vorteks for a couple of weeks, and the only thing I've broken so far are shock shafts (one with the stock plastic shocks and one with the aluminum body shocks), so I'm trying out some 6s shocks from the shock guide. Just wanted to document it in case anyone was curious!
Before the new shocks went on:
I went with Mojave for rear shocks and Limitless for front shocks. I'm still waiting on parts for the fronts, so I added the rears first!
Here are all the parts I used for the rears:
I used:
Then I added the bushings to the shock tops:
Then I installed one side:
Then the other:
Looks pretty cool so far, the only thing I noticed is that the new shocks make the car sit a little higher.
After I get the parts for the fronts, I'll post some more pictures!
I used:
- 1 set of shocks Mojave 6s front shocks from Jennys: https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
- The recommended springs, Arrma part number ARA330637
- The recommended Axial bushings, part number AXA1356
Then the other:
