6s to 4s balance lead?
mbailey
I have a C240 duo charger and I’ve always used the balance board to charge my lipos that came with it. I recently bought a couple bat safe charge boxes and it’s kinda difficult to setup with the balance boards. I was hoping to find a balance lead that will go straight from the charger into my 4s batteries but the charger input is 6s and my batteries are 4s. I have not been able to find any cables like that. Do they even exist?
Just re-read your post... So I had to edit my answer...
They have 6s balance wire extensions that can make it easier...
Put the extension between the charger and the balance board & put the board in the box with the battery!
RuiLing 2pcs 15cm JST-XH 6S LiPo Balance Power Cable Connector 22AWG Extended Charging Wire Male Female Plug for RC Drone FPV Quadcopter Rechargeable Lipo Battery Charger DIY https://a.co/d/4V0enl5
Or scroll to the right on that Amazon link & get 4s extensions...
But you'll have to buy some for other batteries (2s,3s,6s...etc)you may have or buy in the future...
Another cheaper option...
HobbyPark 2S-6S JST-XH LiPo Battery Balance Charger Extension Cable Balance Charging Wire Lead Adapter for RC Charger(2-Each,10pcs in Total) https://a.co/d/5UxJTvl
That's exactly what I do.👍I keep my balance board inside my safe bag while charging
Here are a couple photos of my setup... I have 4 bat boxes and 2 dual port chargers. 2 of my bat boxes are setup like this for charging.
All the cables disconnect for easy transport.
Great idea!
I have a .50 Cal. Ammo can for lipo storage that I removed all of the seal from except the edge near the latch. The latch mechanism needs that portion to properly lock. Leaving the rest off for venting if there's a fire.
I'm running out of space so I may grab 2 more & some grommets so I can run the leads through them for home & field charge boxes.
Also I am getting into parallel lipo charging since my toolkitRC M6D charger can handle everything I throw at it!
That's how I do it with my Bat-Box. I also keep a charging cable with an EC5 connector semi-permanently installed into the box, and I use an adapter from EC5 to whatever type of charging connector I have on the battery being charged. That way I don't have to fish different charging cables through the Bat-Box seal.
