Coopsonthefarm
Pulled the trigger on the new Kraton! Was qurious about the diffs. Any one opened them up? Are they needing to be shimmed the same way as the v3 line up? Thanks ??
Well being as how the V3 lineup didn't need shims out of the box I am thinking these won't either. It was the V1 and V2 diffs that needed shimming.Pulled the trigger on the new Kraton! Was qurious about the diffs. Any one opened them up? Are they needing to be shimmed the same way as the v3 line up? Thanks ??
They have always come preshimmed 1 shim on either side of the satellite gears, just since the V3 release they changed something to make a vast majority of the diffs not need them.I believe someone also said in the V4 thread that they possibly come shimmed from the factory as one of the unmentioned changes. Don't quote me on that though.
Negative, shimming the outside of the diff does. Part number ARA709057 looks to be the new shims for shimming the crown gear.Does shimming the inside of your diff help prevent stripping the ring and/or pinion gear?
Thanks!! Can’t wait till mine shows up so I can fine out ??I believe someone also said in the V4 thread that they possibly come shimmed from the factory as one of the unmentioned changes. Don't quote me on that though.
