Brushlesspower83
Anyone know where i can order this? I've been looking online and found some similar to it but not the same. thank you.
Weird I can only find this one https://www.ebay.com/itm/ARRMA-V1-V...759035?hash=item1cb382827b:g:9o8AAOSw7speHoi5
thank you very much, going to order.Here you go
thank you very much, going to order if i can living in the United States.Here you go
t bone mud guards.Look on thingiverse.. they are there.. just type arrma and scroll through.. I know there is definitely one for a talion..
The one pictured kind of looks like a tbone part..
??? ok thanks man, good lookin out. I have the T bone racing mudguards I'll probably just stick with this. I don't need it to be a any more of a pain than it's worth.I got this exact one about 2 years ago, I removed if after few packs.
It is just a pain, and it doesn't stop the back end from getting dirty, and also makes it so much harder to clean it back.
it blocks access to the brace screw, the links and the cup set screw.
I got it from this guy, but now I see he sells only the a-arm mud guards.
Easy to make. out of scrap clear packaging. us double face tape to attached.
Here the center mudguards you can get in Germany from POS:
https://www.pos-modellbau.de/shop/mudguards/arrma/
Make your own out of sheet lexan or kydex. Use cardboard as a template first for fitting.
