Bigdog3890
- Granite
- Senton 6s
- Notorious
Are mega and just the 4x4 blx parts interchangeable such as a arms c hubs steering blocks all that ? Looking at buying it all from
Gpm
Gpm
What I do is go to the Arrma website and look up parts. Then click on the part and scroll down. It will state model cross compatibility.Are mega and just the 4x4 blx parts interchangeable such as a arms c hubs steering blocks all that ? Looking at buying it all from
Gpm
https://www.gpmparts.com/arrma-granite-4x4-mega-monster-truck-c-1532_4405_4628.html^this.
The Mega and BLX models share 99.9% of the same parts.
Yes. Again.https://www.gpmparts.com/arrma-granite-4x4-mega-monster-truck-c-1532_4405_4628.html
So if I wanted to get these gpm parts they would fit on my blx ?
Maybe, lol. Do some homework. I clicked on the steering rack setup. Scrolled down and pasted the Arrma part number in the description. Searched it on the Arrma parts page. It said yes. It wouldn’t hurt to check the factory part numbers to the gpm supplied replacement numbers. Save you some headache.https://www.gpmparts.com/arrma-granite-4x4-mega-monster-truck-c-1532_4405_4628.html
I know for fact that the parts in question are the same on both trucks.Maybe, lol. Do some homework. I clicked on the steering rack setup. Scrolled down and pasted the Arrma part number in the description. Searched it on the Arrma parts page. It said yes. It wouldn’t hurt to check the factory part numbers to the gpm supplied replacement numbers. Save you some headache.
Ok thanks bicketybamI know for fact that the parts in question are the same on both trucks.
Do the a arms have different mounting holes for shocks ?I know for fact that the parts in question are the same on both trucks.
I’m tired of plastic shhhhh...... breaking I’ve snapped 3 sets of a arms both front and rear ....That I couldn't tell you. I'd get the RPM arms over the aluminum ones anyway and I know they have different mounting holes.
Yeah I do double flips or land wrong on front or rear a lot but tires if buying a arms over and over again lolDon't think it has anything to do with your driving? When you whack into something with metal a-arms they are either going to bend or where they attach to the truck will break. Neither is a good outcome. But it's your money. Good luck.
and use metal parts else whereYou'll break something else that's harder to replace.
Lörn tu dreif!
Do you plan on making your whole truck metal? ?Yeah I’m thinking rpm arms
This is why Arrma need to sell the Siren 6s. ??Do you plan on making your whole truck metal? ?
Lol if it holds better then plastic breaking every run lolDo you plan on making your whole truck metal? ?
are you replacing with stock plastic? or RPM plastic? not going to lie id be a bit impressed if you were snapping RPM every time out. with stock plastic i wouldnt really doubt it too much (nothing against factory Arrma parts, but stock is stock and RPM is RPM).Lol if it holds better then plastic breaking every run lol
Good call dip em in wd40 over a couple hours to make em flexy wont be good for street driving but great for bashingYeah I’m thinking rpm arms
