Are there center dogbones from Tekno or any other company that fit arrma and are shorter then 82mm?
StephenSchandelmayer
Florida
  1. Gorgon
  2. Mojave 4s
  3. Outcast 4s
  4. Typhon 6s
I have a project in mind and just curious if anyone has the answer to this before I start buying random dogbones to see what works. The 82mm is the short shaft from the typhon so I am looking for shorter than that
How much shorter? A quick search for "dogbone" on JRC netted me this.. there are more, JRC gives dimensions on quite a few..
https://jennysrc.com/products/savag...center-hpi-160101?_pos=9&_sid=7734efbd6&_ss=r
My biggest issue is knowing whether the ball on the end is the same size or not. Hard to tell from pictures and they don't give you the size of that ball too much. Scorched has an 80mm shaft for arrma but I was hoping for something smaller, in the 70's maybe
Sadly its the centers that I need. But I found one thats an HPI that is 78mm so that might work just right
shortening is easy, cut and weld at the ball end. It's lengthening that can be cumbersome without v-blocks and the right fusion setup.
Thats very true I might try that route but I wouldn't mind being able to find exactly what I need already done of course!
