What C rating and size is recommended?
You can only run the the Kraton 6S up to 6S, not 8S. Running those two packs would be 8S.ow about using the 4s 3300 60C in parallel - making it a 6600mah pack? That way I could still use them in my smaller rc airplanes.
Running them in parallel, yes that will work. Just make sure that you can wire them correct.How about using the 4s 3300 60C in parallel - making it a 6600mah pack? That way I could still use them in my smaller rc airplanes.
Hey man - would believe I'm still learning self control? Sometimes I'd like teen and other friends to try it and 6s is just too much! Sometimes I'm in a small space - I wish there was a better way to just adjust the throttle and dial down 6S - especially with the instant - full torque of electrics!OP where is the fun in that! Just drive carefully and don't send it to the moon.
I'm hoping the new trays should help (I have ver2). I was about to ditch 6s after damaging several by ejections and just beating them up while they are in the tray. I'll try adding some padding.You need better straps. If your tray is ejected along with it, you can try this simple mod:
https://www.arrmaforum.com/threads/simple-solution-for-preventing-battery-tray-deployment-6s.14261/
