Arrma Granite BLX problems
Pepijj221
The Granite is not functioning as it should be..
Some time it accelerates without controlling the controller.
Something is wrong with the servo because it steers automatically sometimes.
And then the stutter (haw) of the car..? The weird noise it makes..
The car is just 4 months old.
We checked the differential, no broken things or something.
Any advice?
Thanks.
@Pepijj221 I'd first start by making sure the batteries in the transmitter and receiver are both fully charged then re-bind your receiver and transmitter and see if that makes things any better.
How to bind your Arrma Granite receiver and transmitter
arrma-binding-radio-jpg.9982
  1. Press and hold bind button on receiver.
  2. Turn on your Arrma Granite.
  3. Receiver LED will start to blink, indicating the receiver is in bind mode.
  4. Turn on your transmitter, wait a few seconds.
  5. The LED on your receiver will stop blinking and binding should be complete.
Turn everything off and back on again then check range.
If that doesn't fix it then contact Arrma Support.
Few days ago we braught it to the local re store, they replaced the cooler and reset some things, it drove good after that but today its the same problem as at the begin...
Problem solved.
We went to the local rc store and they checked the battery and concluded it was broken..
They also replaced the receiver. (Under warranty)
