Harlon
- Kraton 6s
When you get your Noble, after installing the reciever your esc is going to switch your reverse with forward. Just reprogram your esc and you'll be all set. You could switch it on your noble as well if you wanted to. If you have problems, I'll help you out if needed ??Just about ready to run! I'm waiting for my FlySky Noble N4 to get here, which is supposed to be Tuesday. Then I can install the receiver, charge things up, and give it a spin. While waiting I've gotten the following:
Apache 2800 protective case
FastEddy sealed bearing set
HR front chassis brace
HR rear chassis brace
JX Ecoboost CLS6322HV servo
MIP metric speed tip set
RPM front bumper
RPM rear skid plate
Venom Pro Duo charger
Zeee 22.2V 100C 6000mAh 6s Lipos
The Apache case is truly awesome. You can customize the inside to hold just about anything of any shape by removing small square sections of the foam to leave the shape you want for things to sit in. I'm rather certain my FlySky transmitter will fit along with my Venom charger. If they won't fit together, then maybe I'll just make it work for the transmitter and create a few spots for Lipos to be held for transport.
View attachment 63991View attachment 63992
